| C5 moottorivikakoodia pukkaa... http://www.sitruunapatonki.fi/forum/viewtopic.php?f=9&t=21108 |
| Kirjoittaja: | tonde [ 12.06.2015 07:38 ] |
| Viestin otsikko: | C5 moottorivikakoodia pukkaa... |
Onkohan kalliskin remppa luvassa....voisko olla hiukkassuodatin tukkeentumassa? c5 2011 ml. 150tkm C5 163hdi 2.0 ***** Error Codes P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance PIDs supported [21 - 40] 00100000000000000000000000000000 Vehicle speed (Speed) 53 km/h Intake manifold absolute pressure (MAP) 112.0 kPa Calculated engine load value (EngineLoad) 38.43 % MAF air flow rate (MAF) 19.75 g/s Engine RPM (RPM) 1984 rpm Engine coolant temperature (ECT) 81 °C Fuel Rail Pressure (diesel, or gasoline direct inject) (FRP2) 270.0 kPa =================== Pending Codes P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance C218F Raw values Error Codes 43012084;; Panding Codes 47012084;618F02;; |
