Päivän harmin aihe
Northstar
Re: Päivän harmin aihe
Ja paha pettymys..Kun jo toinen tilaamani paketti Rockauto.com :ista ei sisältänyt sitä jääkaappimagneettia,joka aina aikaisemmin on ollut paketin pohjalla..Herää epäilys että liittyy "Unioniimme"....
public
Viesti Kirjoittaja public »
Vai olisiko taustalla Magneettimedia? :mrgreen:
IJN
Viesti Kirjoittaja IJN »
Taustalla lienee ihan tylsästi IATAn säännöt magneettisten tavaroiden ilmakuljetuksista. Mahdollista, mutta työlästä+kallista, ainakin ilmaisten kaupanpäällisten kanssa..
In Order for Magnets to be Shipped by Air
For air shipment purposes, magnets are considered "dangerous goods". As such, the International Air Transport Association's (IATA) Dangerous Goods Regulations (DGR) must be followed.
Flux measurements of all packages containing magnets must measure less than 0.00525 gauss 15’ from the package. If flux measurements are less than 0.002 gauss when measured 7’ from the package, the package is not considered to contain magnetic material, and hence is not classified as Dangerous Goods. However, unless the package is extremely secure and there is no chance that the contents will shift or that shielding will be damaged in transit, it is safer to proceed as though the package falls under the DGR.
Packages containing magnetic materials must be clearly identified according to Packing Instructions 902. This calls for a "Magnetized Material" label to be affixed, and for a Shipper's Declaration of Dangerous Goods to be provided to the carrier.
Personnel responsible for shipping magnets by air are required by the Federal Aviation Authority (FAA) to be trained for that purpose and for those training records to be maintained. Contact your carrier for more information and guidelines.
Note that, in addition to transportation costs, Dangerous Goods fees apply to each package shipped by air, oftenmaking shipping magnets by air quite costly.
Northstar
No,ilmeisesti IATA:n kontrolli petti,sillä Jeepin ylätukivarsien etuhelojen mukana sitten tuli magneetti. :D
Sitruunaseppä
Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
pvalila
Viesti Kirjoittaja pvalila »
Sitruunaseppä kirjoitti:Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
Kaikki tiet vievät Turkuun, jo vanhat roomalaiset tiesivät sen...
Nähdä Naantali ja kuolla, oli kai se toinen heidän viisautensa.
jotunen
Viesti Kirjoittaja jotunen »
Invapaikalle ajavat kirjakansan edustajat :oops: ,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista :?:
Iso mies ja pienet sitruunat.
Ralle
Viesti Kirjoittaja Ralle »
jotunen kirjoitti:Invapaikalle ajavat kirjakansan edustajat :oops: ,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista :?:
Sanotaan nyt, että itseä ainakin Vee-tuttaa oli kuka tahansa joka ei jaksa kävellä jos se onnistuu.
Kerran yritin ehdottaa paikallislehdelle et olis tehnyt jutun näistä turhaan invapaikalle parkkeeraajista. Vissiin liian pieni city kun ei ole uskallusta riittänyt. :lol:
Esimerkiksi jo 80-luvulla Karpon ohjelmasta (aikamoinen aasin silta, kuka muistaa jakson) tullut Heinoska omistaa kyseisen ruudun vieressä pankkiautomaatin jonka käyttäjät ajaa säännöllisesti invapaikalle. Oikein pysähtymällä viereiseen ruutuun tulisi matkaa lisää ..... :roll: Metri tai pari...
jotunen
https://www.youtube.com/watch?v=l9qnAIXpGLU" onclick="window.open(this.href);return false;
Säxä77
Viesti Kirjoittaja Säxä77 »
Itse olen miettinyt että leikkaisi mustasta jeesusteipistä pienet hameen muotoiset palat ja liimaisin ne invapaikan kyltteihin sen pyörätuolin päälle. Hyvässä lykyssä siitä tulisi nettimeemi ja somekohu joille salaa hihitellä ja vielä paremmalla tuurilla syntyisi keskustelua tärkeästä asiasta. Sukulaisilla on invatunnus ja ihan tarpeellinen, heillä jokainen ilman tukea kävelty metri näyttää olevan tuskaa.
Aakku
Viesti Kirjoittaja Aakku »
Citroën 2CV AZ Berline -56
citrophoros
Kuuluisin henkilö, jonka selän takana olen odottanut vuoroani Otto-automaatille, on kuollut.
Waldemar Wallenius.
25 C5 X PureTech 225
21 C4 PureTech 130
19 C3 Aircross 110
15 C4 Aircross 1,6i
12 C4 VTi 120 Exclusive
05 C4 1,6i 16v VTR coupé
03 C5 2,0i 16v SX berline
98 Xsara 2,0i VTS coupé
95 ZX 1,9i Volcane berline
93 BX GTI berline
91 Visa 14 TRS berline
pvalila
Aakku kirjoitti:Kuva
Myös HSL:n busseissa on vatsakkaille miehille varattuja paikkoja. Symboli on sama, mutta ilman grilliä.
Säxä77
Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
jptcool
Viesti Kirjoittaja jptcool »
Säxä77 kirjoitti:Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Ehkä ne ovat tulleet persukarvan verran järkiinsä, jota tosin uskallan eppäillä
Xari
Viesti Kirjoittaja Xari »
jptcool kirjoitti:
Se on pakko olla pakkoruotsia kun Ahvenanmaalaiset ei osaa suomea :lol: https://yle.fi/uutiset/3-12219140
Käsittämätön vuosisataisten sortovuosien mukana tullut muinaisjäänne jota kukaan ei kumminkaan viitsi pakollakaan opetella, mäkin kysyin kerran meidän pakkoruotsilla kidutetulta että tules kääntämään mulle vähän Bloketin autoilmoitusta, katseli vähän ja tuumasi ettei ymmärrä tuosta yhtään mitään :lol:
ilkkata
Viesti Kirjoittaja ilkkata »
Vähintään 3kk ajokielto :cry:
Ralle
ilkkata kirjoitti:Vähintään 3kk ajokielto :cry:
tuliko kiintiö täyteen?
ilkkata
Ralle kirjoitti:
Aivoinfarkti
Ralle
ilkkata kirjoitti:
Ralle kirjoitti:
Aivoinfarkti
Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa. :(
Kaveri tais kanssa saada samamoisen vuosia sitten ja kortista lähti muut kuin b, ammattilupa lähtikin sitten 5 vuodeksi.
Paranemisia ja toivotaan pikaista kortin paluuta.
Ralle kirjoitti: Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa. :(
Naapuri sai taannoin vuoden ajokieltoa, lääkäri väitti että on epilepsia vaikka itse väitti kivenkovaan, ettei siitä ollut kyse.
Vuoden päästä kun alkoi kysellä ajolupaa takaisin, selvisi ettei mitään ajokieltoa ollut ollutkaan.
Taisi lekuri alkaa itsekin epäillä diagnoosiaan, mutta ei kehdannut myöntää sitä potilaalle...
Oman harmin aiheena sain eilen opetuksen siitä, että öljyntäyttökorkki kannattaa laittaa kiinni heti eikä 800km ajon jälkeen. Tommonen bokseri ruiskii sitä aika kivasti joka paikkaan kun nokkaketju kulkee täyttöreiän alta... :oops:
Northstar
Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Northstar
Jos on Subarusta kyse,niin pidentää auton elinkaarta huomattavasti.. :D
pvalila
Northstar kirjoitti:Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Tarkentavana kysymyksenä: kirvelivätkö ne kahdesti samassa osassa kehoa? Poistuivat siis samaa tietä kuin tulivat sisään? :roll: :roll: :roll:
Peksi
Viesti Kirjoittaja Peksi »
Eturengas tyhjeni Porvoossa eilen illalla. Siis ajossa, ensin ihmettelin että onko sähköinen ohjaustehostin jotenkin rikkoutumassa, kunnes oireet selvenivät kolmen km:n ajon jälkeen. Lelumetallivanteen sisäkehällä (?) painuma, josta ilma puolessa vuorokaudessa pihalle? Putosin sisäkaarteessa asfaltin reunalta, kantatiellä. Eikä edes maalipinnassa naarmua…
