Sivu 89/94
Re: Päivän harmin aihe
Lähetetty: 28.10.2021 20:43
Kirjoittaja Northstar
Ja paha pettymys..Kun jo toinen tilaamani paketti Rockauto.com :ista ei sisältänyt sitä jääkaappimagneettia,joka aina aikaisemmin on ollut paketin pohjalla..Herää epäilys että liittyy "Unioniimme"....
Lähetetty: 29.10.2021 11:42
Kirjoittaja public
Vai olisiko taustalla Magneettimedia?
Lähetetty: 29.10.2021 12:50
Kirjoittaja IJN
Taustalla lienee ihan tylsästi IATAn säännöt magneettisten tavaroiden ilmakuljetuksista. Mahdollista, mutta työlästä+kallista, ainakin ilmaisten kaupanpäällisten kanssa..
In Order for Magnets to be Shipped by Air
For air shipment purposes, magnets are considered "dangerous goods". As such, the International Air Transport Association's (IATA) Dangerous Goods Regulations (DGR) must be followed.
Flux measurements of all packages containing magnets must measure less than 0.00525 gauss 15’ from the package. If flux measurements are less than 0.002 gauss when measured 7’ from the package, the package is not considered to contain magnetic material, and hence is not classified as Dangerous Goods. However, unless the package is extremely secure and there is no chance that the contents will shift or that shielding will be damaged in transit, it is safer to proceed as though the package falls under the DGR.
Packages containing magnetic materials must be clearly identified according to Packing Instructions 902. This calls for a "Magnetized Material" label to be affixed, and for a Shipper's Declaration of Dangerous Goods to be provided to the carrier.
Personnel responsible for shipping magnets by air are required by the Federal Aviation Authority (FAA) to be trained for that purpose and for those training records to be maintained. Contact your carrier for more information and guidelines.
Note that, in addition to transportation costs, Dangerous Goods fees apply to each package shipped by air, oftenmaking shipping magnets by air quite costly.
Lähetetty: 30.10.2021 15:52
No,ilmeisesti IATA:n kontrolli petti,sillä Jeepin ylätukivarsien etuhelojen mukana sitten tuli magneetti.
Lähetetty: 30.10.2021 16:50
Kirjoittaja Sitruunaseppä
Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
Lähetetty: 30.10.2021 18:29
Kirjoittaja pvalila
Sitruunaseppä kirjoitti:Ilmalaivoissa on moninkertaiset suuntimavälineet ja lentäjän kännykässä pari appia lisää. Kun mä olin pienempi, olin poistamassa magneettisuutta valtamerilaivassa, kun hitsauskaapelit oli magnetoineet paikkoja. Kompassi näytti Turkuun, kun piti nimenomaan välttää tuo kaupunkien kaupunki.
Kaikki tiet vievät Turkuun, jo vanhat roomalaiset tiesivät sen...
Nähdä Naantali ja kuolla, oli kai se toinen heidän viisautensa.
Lähetetty: 02.11.2021 11:29
Kirjoittaja jotunen
Invapaikalle ajavat kirjakansan edustajat
,siis suorastaan vit...aa.Itsellä lupa ja kun nuo liikkumiseen tarkoitetut raajat oikein vihoittelee,ni eikö perkele joku ko.ryhmän edustaja ole ajanut paikalle.Mahtaakohan bannit iskeä facessa jos alkaisi laittaa kuvia autoista
Lähetetty: 02.11.2021 18:27
Kirjoittaja Ralle
jotunen kirjoitti:Invapaikalle ajavat kirjakansan edustajat
Sanotaan nyt, että itseä ainakin Vee-tuttaa oli kuka tahansa joka ei jaksa kävellä jos se onnistuu.
Kerran yritin ehdottaa paikallislehdelle et olis tehnyt jutun näistä turhaan invapaikalle parkkeeraajista. Vissiin liian pieni city kun ei ole uskallusta riittänyt.
Esimerkiksi jo 80-luvulla Karpon ohjelmasta (aikamoinen aasin silta, kuka muistaa jakson) tullut Heinoska omistaa kyseisen ruudun vieressä pankkiautomaatin jonka käyttäjät ajaa säännöllisesti invapaikalle. Oikein pysähtymällä viereiseen ruutuun tulisi matkaa lisää .....
Metri tai pari...
Lähetetty: 02.11.2021 18:47
Kirjoittaja jotunen
https://www.youtube.com/watch?v=l9qnAIXpGLU" onclick="window.open(this.href);return false;
Lähetetty: 02.11.2021 23:27
Kirjoittaja Säxä77
Itse olen miettinyt että leikkaisi mustasta jeesusteipistä pienet hameen muotoiset palat ja liimaisin ne invapaikan kyltteihin sen pyörätuolin päälle. Hyvässä lykyssä siitä tulisi nettimeemi ja somekohu joille salaa hihitellä ja vielä paremmalla tuurilla syntyisi keskustelua tärkeästä asiasta. Sukulaisilla on invatunnus ja ihan tarpeellinen, heillä jokainen ilman tukea kävelty metri näyttää olevan tuskaa.
Lähetetty: 03.11.2021 08:41
Kirjoittaja Aakku
Lähetetty: 25.11.2021 00:09
Kirjoittaja citrophoros
Kuuluisin henkilö, jonka selän takana olen odottanut vuoroani Otto-automaatille, on kuollut.
Waldemar Wallenius.
Lähetetty: 25.11.2021 23:47
Kirjoittaja pvalila
Aakku kirjoitti:
Myös HSL:n busseissa on vatsakkaille miehille varattuja paikkoja. Symboli on sama, mutta ilman grilliä.
Lähetetty: 10.12.2021 21:39
Kirjoittaja Säxä77
Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Lähetetty: 10.12.2021 21:46
Kirjoittaja jptcool
Säxä77 kirjoitti:Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Ehkä ne ovat tulleet persukarvan verran järkiinsä, jota tosin uskallan eppäillä
Lähetetty: 11.12.2021 00:45
Kirjoittaja Xari
jptcool kirjoitti:Säxä77 kirjoitti:Perussuomalaiset näköjään luopuvat pakollisen ruotsinopetuksen vastustamisesta. Ymmärrän kyllä että politiikassa pitää tehdä kompromisseja että pääsee pöytiin jossa päätökset tehdään, mutta siinä käy helposti niin ettei enää ole periaatteita joita puolustaa eikä kohta enää kannattajiakaan. Luulisi että nykyisillä kannatusluvuilla olisi varaa olla vähän jyrkempikin.
Se on pakko olla pakkoruotsia kun Ahvenanmaalaiset ei osaa suomea
https://yle.fi/uutiset/3-12219140
Käsittämätön vuosisataisten sortovuosien mukana tullut muinaisjäänne jota kukaan ei kumminkaan viitsi pakollakaan opetella, mäkin kysyin kerran meidän pakkoruotsilla kidutetulta että tules kääntämään mulle vähän Bloketin autoilmoitusta, katseli vähän ja tuumasi ettei ymmärrä tuosta yhtään mitään
Lähetetty: 13.12.2021 12:22
Kirjoittaja ilkkata
Vähintään 3kk ajokielto
Lähetetty: 13.12.2021 14:36
Kirjoittaja Ralle
ilkkata kirjoitti:Vähintään 3kk ajokielto
tuliko kiintiö täyteen?
Lähetetty: 13.12.2021 19:45
Kirjoittaja ilkkata
Ralle kirjoitti:ilkkata kirjoitti:Vähintään 3kk ajokielto
Aivoinfarkti
Lähetetty: 13.12.2021 21:26
Kirjoittaja Ralle
ilkkata kirjoitti:Ralle kirjoitti:ilkkata kirjoitti:Vähintään 3kk ajokielto
Aivoinfarkti
Ai hitto. Niin se taitaa olla vakio juttu noissa "pää" tapauksissa.
Kaveri tais kanssa saada samamoisen vuosia sitten ja kortista lähti muut kuin b, ammattilupa lähtikin sitten 5 vuodeksi.
Paranemisia ja toivotaan pikaista kortin paluuta.
Lähetetty: 14.12.2021 10:46
Kirjoittaja Teuski
Ralle kirjoitti:
Naapuri sai taannoin vuoden ajokieltoa, lääkäri väitti että on epilepsia vaikka itse väitti kivenkovaan, ettei siitä ollut kyse.
Vuoden päästä kun alkoi kysellä ajolupaa takaisin, selvisi ettei mitään ajokieltoa ollut ollutkaan.
Taisi lekuri alkaa itsekin epäillä diagnoosiaan, mutta ei kehdannut myöntää sitä potilaalle...
Oman harmin aiheena sain eilen opetuksen siitä, että öljyntäyttökorkki kannattaa laittaa kiinni heti eikä 800km ajon jälkeen. Tommonen bokseri ruiskii sitä aika kivasti joka paikkaan kun nokkaketju kulkee täyttöreiän alta...
Lähetetty: 06.01.2022 19:01
Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Lähetetty: 06.01.2022 19:04
Teuski kirjoitti:Ralle kirjoitti:
Jos on Subarusta kyse,niin pidentää auton elinkaarta huomattavasti..
Lähetetty: 15.01.2022 12:51
Kirjoittaja pvalila
Northstar kirjoitti:Eilen Lidlistä ostamani "Stinger" kanankoivet kirvelivät mennen tullen...
Tarkentavana kysymyksenä: kirvelivätkö ne kahdesti samassa osassa kehoa? Poistuivat siis samaa tietä kuin tulivat sisään?
Lähetetty: 15.01.2022 21:47
Kirjoittaja Peksi
Eturengas tyhjeni Porvoossa eilen illalla. Siis ajossa, ensin ihmettelin että onko sähköinen ohjaustehostin jotenkin rikkoutumassa, kunnes oireet selvenivät kolmen km:n ajon jälkeen. Lelumetallivanteen sisäkehällä (?) painuma, josta ilma puolessa vuorokaudessa pihalle? Putosin sisäkaarteessa asfaltin reunalta, kantatiellä. Eikä edes maalipinnassa naarmua…
