Onkohan kalliskin remppa luvassa....voisko olla hiukkassuodatin tukkeentumassa?
c5 2011 ml. 150tkm
C5 163hdi 2.0
Error Codes
P2084
Exhaust Gas Temperature Sensor Circuit Range/Performance
PIDs supported [21 - 40] 00100000000000000000000000000000
Vehicle speed (Speed) 53 km/h
Intake manifold absolute pressure (MAP) 112.0 kPa
Calculated engine load value (EngineLoad) 38.43 %
MAF air flow rate (MAF) 19.75 g/s
Engine RPM (RPM) 1984 rpm
Engine coolant temperature (ECT) 81 °C
Fuel Rail Pressure (diesel, or gasoline direct inject) (FRP2) 270.0 kPa
Pending Codes
P2084
C218F
Raw values
Error Codes 43012084;;
Panding Codes 47012084;618F02;;
